| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | when replacing clutch disc which way do the springs go, toward the flywheel or toward the pressure plate? 46 1/2 ton
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Look very closely at the clutch disc; most say "toward flywheel" or "flywheel side".
Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i need to know if I put my disc in wrong | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | The springs go away from the flywheel. If they are installed towards the flywheel they will rub against the flywheel bolts. (I know this because the previous owner of my replacement engine installed the disk backwards. LOL.) | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Did you look at the illustration that was posted???? The long part of the hub towards the front is another clue.
dg
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | ok, I got it in right, but when I let the clutch out it makes a noise like something is hitting in there, I cant find any marks where it would hit....maybe if I backoff on the clutch adjustment?? Maybe shim out the starter? trying all options at this point | | |
