2 members (1955 1 Series, Peggy M), 90 guests, and 2 robots.
Topics128,094
Posts1,056,465
Members48,443
#1090397 03/09/2015 3:25 AM
Hello all,
I am looking for a set of original parking light housings for my 1950 GMC. I am a machinist by trade and plan on making a new set of housings out of stainless steel. I need an original to measure. I will make a set of stainless ones for anybody letting me borrow one to copy. i will also sell sets to anyone else interested. I will have a price once I get the first set mocked up.
Ron
1950 Gmc 100
Hello all,
I got a response from Tim. He was kind enough to send me a housing assembly. I have finished drawing all the parts up in Autodesk Inventor. I was going to post a screen shot of the drawing but couldn't find the file manager to upload the image. I am ready to start making parts. If I can figure out how to upload pics I will post them as I finish parts. I am planning on making a few sets of these. I will be keeping one set for myself and sending a set to Tim for letting me borrow his housing. These will all be made from stainless steel. I will be putting double filament socket in mine so I can have both running lights and turn signals.
1950 Gmc 100
Ok I think I got the link for the picture right.
GMC parking light housing assembly
http://i1226.photobucket.com/albums/ee412/MOTOXFAMILY1914/6-18-2015%203-07-04%20PM_1.jpg
1950 Gmc 100
The drawing looks great. I bet there would be some interest in your housings over at oldgmctrucks.com forums. Where are you in Nor Cal?
1956 GMC 100 NAPCO Deluxe
1955.1 Chevy 3600 NAPCO
1954 Chevy 3600 NAPCO
They are being reproduced already. A bit pricey so you might be able to compete:
http://www.amazon.com/1955-1957-Corvette-Parking-Light-Assembly/dp/B002MREUH8
dg
Denny G
Sandwich, IL
I am in Novato. 1/2 hour north of golden gate bridge. I do have a post over at oldgmctrucks as well.
1950 Gmc 100
I believe early Corvettes use the same assembly. Another sales option.
Check to verify.
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
Thanks Bruce, guess I should have clarified that they use
the same assembly.
That was the link that I posted, it's Amazon but the order
goes to Corvette Central. Haven't seen them any cheaper, but
then again I'm not in need and haven't looked all that hard.
dg
Denny G
Sandwich, IL
The Corvette replacements and the Chevy backup lights will be correct for a '51-'53 GMC. They are not correct for a '47-'50 GMC.
Also, if I remember correctly, the Chevy backup lights use a different mounting gasket than the GMC to compensate for the curve in the Chevy body.
I might be wrong Charlie, you're the expert on the GMC's, but
isn't the earlier Jimmy light the one that is the same as
the Vette? That's the one with the 'Bee-Hive lens and U-shaped
retainer bracket in the back. The later housing is simply
mounted thru the fender with studs and uses a shallower lens?
This is an illustration by Rob English:
http://www.pbase.com/dennygraham/image/155221077
Corvette Central:
http://www.pbase.com/dennygraham/image/160519395
dg
Denny G
Sandwich, IL
I don't know about the rest of the light, but the p/n for a 47-50 GMC lens is 5936929. That is the same p/n for a Corvette. I'm not sure about the rest of the parts. The illustration Rob copied is directly out of the GMC master parts book.
Yes and what little I've studied on the part numbers, that
sounds correct.
Thought I was going to make a killing on casting accurate
reproduction parking light lenses for early Jimmy's a while back:
http://www.pbase.com/dennygraham/image/155273248
Then I found out every one and his brother was making them
for ten bucks or less. Guess I should have dome my homework
before investing the time and material on mold and resin.
Oh well...........taint like it's the first mistake I've ever made.
dg
Denny G
Sandwich, IL
