9 members (Samantha, Forty9, texas46, Rustnut, IHPWR, Bill Hanlon, DadsFirstPickup, 32Fordpuchoptop, 1 invisible),
140
Mod | | | Forums66 Topics128,108 Posts1,056,236 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Hi All,
I've been disassembling the original engine/transmission from my 1947 3100. When I got the flywheel housing off, I noticed some deep grooving and wear on the clutch fork pivot ball. The clutch fork socket is also worn.
The pivot balls are readily available, but the clutch forks are not. What is the preferred approach to this? Is only the ball replaced? Is a service "socket" available? Grease it and hope for the best?
Thanks in advance for the advice,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Pivot balls and forks show up on eBay all the time. Fork fits: 1947-59 truck 1940-54 pass
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd replace the ball for sure, fork shouldn't be difficult to find. Place an ad here on the bolt to see if you can find a better fork.
Great looking truck BTW!
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Thanks for the re-direct and advice, JiMerit & Pre'68 Dave. And thanks for the compliments on my project  . I've located a couple of clutch forks on line and will make a decision once I get the used one cleaned up. Best regards, Bill
