Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TooMany2count, 60steve, Lightholder's Dad, klhansen), 140 guests, and 1 robot.
Topics128,277
Posts1,058,451
Members48,490
#1109418 06/22/2015 1:24 AM
Hi All,
I've been disassembling the original engine/transmission from my 1947 3100. When I got the flywheel housing off, I noticed some deep grooving and wear on the clutch fork pivot ball. The clutch fork socket is also worn.
The pivot balls are readily available, but the clutch forks are not. What is the preferred approach to this? Is only the ball replaced? Is a service "socket" available? Grease it and hope for the best?
Thanks in advance for the advice,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Pivot balls and forks show up on eBay all the time.
Fork fits:
1947-59 truck
1940-54 pass
My Blog
I'd replace the ball for sure, fork shouldn't be difficult to find. Place an ad here on the bolt to see if you can find a better fork.
Great looking truck BTW!
1946 1/2-Ton Chevy
Thanks for the re-direct and advice, JiMerit & Pre'68 Dave. And thanks for the compliments on my project smile.
I've located a couple of clutch forks on line and will make a decision once I get the used one cleaned up.
Best regards,
