| | | Forums66 Topics128,196 Posts1,057,387 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 23 Junior Member | | Junior Member Joined: Mar 2004 Posts: 23 | Has anyone seen any good books etc where to learn about body work. The subject had too much info to ask "how do I paint my truck" here. I want to do it myself and want to do it right and only once would be a plus. THanks  | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I plan on going to a school for auto body collision. Hopefully after I do that and finish, i would then like to learn automotive painting.
Stovebolt-It is painted
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | One book that really helped me was "How to Build Real Hot Rods" by LeRoi Tex Smith. Copyright on my book is 1988 published by Motorbooks International. Filled with great how-tos and step by steps.
Good luck. Kim | | | | | Joined: May 2005 Posts: 8 Junior Member | | Junior Member Joined: May 2005 Posts: 8 | I bought the same book on Kim's advice, its very good. | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I got sick and tired of taking my car into the body shops and paying big bucks for shoddy work so I learned how to do body / paint work through the school of hard knocks. I bought a basic book on body work and painting but it didn't help much. Just ask a lot of questions at the paint store and don't be afraid to start banging, filing, scraping, filling on your truck. The body work is the hard part. Painting is fun.
Here are a few tips:
#1. Spray large wavy panels with a heavy building primer then wet sand then smooth with a good quality sanding "block". Then go over the area with fine grit ( 400+ ) wet sand and wipe it clean with a towel. look closely from a shallow angle to see if the waves are gone. If not repeat the process. If you cannot get it smooth you may have to file some of the high areas.
#2. Use body putty for the small dings and Bondo for the large dents ( after you have popped them out as much as possible ) . You can use the body putty over the bondo to achieve a perfectly smooth finish.
#3. Get some cheap spray primer at Wal-Mart so that you won't have to keep mixing primer for your spray gun for the small primer jobs.
#4. Mix your paint as per the instructions on the label, and use hardener. To thick and it will be rough. To thin and it will be drippy.
#5. Don't be afraid to make mistakes. Just go for it.
delete my account and pictures
