0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 2 Junior Member | | Junior Member Joined: Sep 2002 Posts: 2 | i was wondering if there is a difference between the 54 1/2 ton and 52 3/4 ton inner fenders, fender braces, and the core support? im fixing up the 54, but someone tore out holes in the inner fenders and there covered with rust. the stuff on the 52 are nice, no dents, and powdercoated so.... thanks for the help. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The 47-53 & 54/55 1st inner front fenders are different. If ya want to use the 54/55 's on an earlier truck they will have to be notched [ where they meet the grill ]. Use your rusty ones as a guide to what has to be morticed out. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Correction.. if ya want to use the 47-53's on the 54/55 they will have to be notched. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This may not be important regarding the radiator support/frame (radiator core?) but in 1954 the horn was attached to the radiator support/frame. I am not sure when this changed but in prior years the horn was mounted on the front of the intake manifold (in those trucks there are no factory holes in the radiator support/frame for mounting horns).
The 1954 radiator support/frame had attachment points for dual horns (I can't remember if they were threaded holes or captive nuts).
Tim | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Most of us here are captive nuts
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Yea ,I am the most captive nut of 'em all  | | | | | Joined: Jun 2002 Posts: 96 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 96 | I thought all the captive nuts were in Camp X-ray
Send David Hicks home - now! "Better to be wrong and kill no one then right with mass graves" Albert Camus
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | You qualify as a nut after your hot plate post Knucklehead. | | |
