1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#110927 09/19/2002 9:28 PM
Junior Member
Junior Member
i was wondering if there is a difference between the 54 1/2 ton and 52 3/4 ton inner fenders, fender braces, and the core support? im fixing up the 54, but someone tore out holes in the inner fenders and there covered with rust. the stuff on the 52 are nice, no dents, and powdercoated so.... thanks for the help.
#110928 09/20/2002 4:03 AM
Anonymous
Unregistered
Anonymous
Unregistered
The 47-53 & 54/55 1st inner front fenders are different. If ya want to use the 54/55 's on an earlier truck they will have to be notched [ where they meet the grill ]. Use your rusty ones as a guide to what has to be morticed out.
#110929 09/20/2002 4:06 AM
Anonymous
Unregistered
Anonymous
Unregistered
Correction.. if ya want to use the 47-53's on the 54/55 they will have to be notched.
#110930 09/20/2002 5:29 AM
This may not be important regarding the radiator support/frame (radiator core?) but in 1954 the horn was attached to the radiator support/frame. I am not sure when this changed but in prior years the horn was mounted on the front of the intake manifold (in those trucks there are no factory holes in the radiator support/frame for mounting horns).
The 1954 radiator support/frame had attachment points for dual horns (I can't remember if they were threaded holes or captive nuts).
Tim
#110931 09/21/2002 9:38 AM
Most of us here are captive nuts grin
#110932 09/22/2002 2:09 AM
Anonymous
Unregistered
Anonymous
Unregistered
Yea ,I am the most captive nut of 'em all grin
#110933 09/26/2002 4:09 AM
I thought all the captive nuts were in Camp X-ray grin
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
#110934 09/27/2002 6:42 AM
Anonymous
Unregistered
Anonymous
Unregistered
You qualify as a nut after your hot plate post Knucklehead.
