2 members (DadsFirstPickup, Otto Skorzeny), 57 guests, and 2 robots.
Topics128,154
Posts1,056,840
Members48,456
#1109204 06/20/2015 4:30 PM
Where can I find front shoes, wheel cylinders and hardware for my '50 6400 2ton? New, or used, I just need useable parts.
Mike
210-723-1819
[email protected]
3B Offline
Hy FASTRED68, wheel cylinders are still available
at RockAuto Raybestos p/n WC3406 $23.79
at Napa their p/n UP3406 $31.50
as to the shoes, you could have them relined, contact a truck shop in your area and ask who relines their shoes for them, Hope that helps.
Amazon.com has gotten pretty big in to Raybestos parts. On this particular part they are a buck cheaper and with $35 you get free shipping. Raybestos is my brand of choice for old vehicles. Some of it is US and some of it is Chinese, but the quality looks as good as what we bought over 50 years ago.
NOS shoes hit eBay quite often. They are probably asbestos, but I used asbestos pads from the 50's until non asbestos came out. If your shoes are rusty or need to be recoined, you might look at NOS shoes and have new pads put on them if you are afraid of asbestos.
Well, unfortunatly I dont have any core shoes to be re-lined. Like a dummy I took them off and threw them out.
Do you happen to know what part number to search for on Amazon? I havent found anything for a 2 ton truck
Mike
I could be wrong but shoes are not made anymore for 1.5 and 2 tons. I would try in the parts wanted section for some used/new shoes. I belive the cylinders mentioned above are not for the big trucks either the one for your truck would be $60 to $80 a piece or somewhere around there I think rockauto,napa,chev of the 40's,jim carter's,etc
1947.5 Chevy 4100 red primer
1951 Chevy 4400 grey primer
If they are the same shoes as a 46 I believe I could dig up the set that I took off when I did the disc brakes on mine. Anyone know if they are the same?
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
1940 through 1950 use a GM no. 366054 shoes so a 46 should work. GMC used that samee number on their one ton through 2 ton. As for the wheel cylinders, it takes a GM 5300869 wheel cylinder. As stated earlier, the aftermarket number is WC3406 in either Raybestos or Dorman.
