9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#1108915 06/18/2015 6:07 AM
Have a 216 in line 6. Positive ground 6 volt system. Started and ran, albeit rough, prior to "fix" - replacing points, plugs, plug wires, rotor, coil, and distributor cap.
Put new ground on battery and new terminal end on "hot" neg wire. Cleaned all ends. I seem to get spark to points and spark to plugs. I have firing order as 153624 starting clockwise from under the right side clip on distributor.
Cranks but no sign of firing, even with the evil starter fluid. It's getting gas. Battery is fully charged and new but it wears down pretty quickly.
Other than my incompetence, any ideas re the culprit?
Can I jump with my car to hep get it fired?
Thoughts??? Thanks!!
A 1938 Chevrolet would have a negative ground electrical system (GMC had a positive ground electrical system).
http://chevy.oldcarmanualproject.com/shop/1938/38csm243.html
You will also need to polarize your generator (look at NOTE on this page).
Ex Hall Monitor
Ex Hall Monitor
Tim, you'll know this better than I. If he connected a Chevy with positive ground would it fry the coil?
ohwell
I don't think reversing polarity on a Chevy will fry the coil. I have been told by a couple of engineers that the voltage out of the coil will be somewhat less but the vehicle could/should run.
When I got my COE, the previous owner had reversed polarity with no apparent permanent ill effects.
My Diamond T is positive ground, and when I had a senior moment and installed the battery with negative ground, I fried the original voltage regulator (Autolite type). I guess a Delco-Remy regulator can work with positive or negative ground.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Thanks to you both!!! I'll flip the battery, re-polarize the generator and see what happens. I'll bring a new coil just in case.
