| | | Forums66 Topics128,083 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | I have just installed a 3.54:1 ring and pinion gear set in a 51 3100. For sanity sake I am looking for opinions on a gear pattern that I believe will work. Pattern1 (Drive side) Pattern2 This is a process that if not done right can get expensive fast. Thanks in advance Walt Williams La Verkin, UT.
| | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | Close, but no seegar- - - - -the pattern needs to move a little toward the outer diameter of the ring gear. Are you putting the brakes on the pinion flange in any way? I usually have someone wrap a couple of turns of rag around the pinion flange and hold it tight while I turn the ring gear back and forth with a box end wrench on one of the ring gear attaching bolts. It makes for a more distinct wipe on the teeth that way. Jerry
| | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | The pattern is off the edges, but not where I would like it to be. At the moment I do not have any more shims to insert. Do you know where I can get more shims to use here?
Walt
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try moveing the ring gear away from the pinion a couple of notches with the adjusters. Then check it again. It might fall in. It is close now. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
