4 members (78buckshot, klhansen, 2 invisible),
147
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 24 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 24 | Hello,
I am replacing the brake system (shoes, cylinders, lines, etc.) on my 54 Chevy 3100 1/2 ton truck. Someone has done work on the truck before so there are times when I'm not sure what is original or not.
In evaluating the current brake lines there is a junction block (T) on the front right frame (one line comes from the master cyl, one line goes to the front right wheel cylinder and the other to the rear).
Yet, I have checked with 3 online parts stores (Inline Tube, American Classic and Car & Truck) and they don't carry this part.
I ordered the pre-bent lines so I'm waiting to receive them to figure out how they should go in.
Does anyone know if the original truck came with that T-Block and if so where I might find a replacement? The lines I'm using are 3/16.
Thanks in advance, Victor
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** My 52 is exactly as you describe yours. ** | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 51 1 Ton is the same. I did not replace my junction blocks. They are brass and don't rust. I did make sure they were clean. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and my 52 panel has that same brass "T" block as the original poster described. Clean it up and it should be find. | | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | Hi Victor, I have had good luck cleaning up the brass and putting it right back in service. Out of curiosity what type of fluid are you planning to put in the truck when you're finished?
Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Nov 2014 Posts: 24 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 24 | Thank you all for your quick and helpful responses:
Jon G - Thanks - I called that business and they don't carry this specific fitting with the ability to bolt it to the frame.
Thank you Marzach and others for confirming on your trucks.
Thanks AmtrakJoe, Truckernix and Achipmunk for that option. May be a dumb question - Any guidance on what you used to clean it?
In considering the re-use of the existing junction block - the current set up looks like it has a larger line for the run from the block to the Master. Smaller lines that run from the block to the front and rear.
When I ordered my lines, they told me they are all 3/16 but they won't tell me what the thread sizes are on the fittings. It seems to me the issue is less about the size of the line vs. the thread sizes on the line fittings. Is that a correct assumption?
Thanks again for all of your help. Victor
| | | | | Joined: Nov 2014 Posts: 24 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 24 | Hi Joe,
I did not have a specific fluid in mind. Do you have a recommendation?
Thanks, Victor | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | panchos, your right. Quarter inch to the fitting and then 3/16 each way to front and back. By cleaning I simply wash out the fitting hole's and brush up the brass on the wire grinder. Clean/blow it out good making sure the threads are good and clean. Don't use anything with silicone in it around the brakes. DOT 3 brake fluid is good. I think my current bottle has DOT 4/5 on it and is synthetic. Do not use silicone fluid and don't ever let it contaminate what you have....or if you go silicone don't get it mixed with the regular stuff.
Most brake lines, if you buy them local, will have a paper tag on them stating they are either Standard, or Metric. To be sure what you were sent I would just try the brass block on the ends first to verify the sizes match...... a nice "thread guage" is handy to have around the shop to tell you what the size/threads are on stuff. Just My opinions.... | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | My 49 had 3 of those "T" blocks, one at the master cyl to main line junction, one on the frame at the right front wheel and the last one at the rear where the soft line to the axle goes. I cleaned all of them up and reused them. I also ordered the prebent hard line kit and mine fit perfectly, which surprised me. Had to chase down several small leaks but once I had all the connections good and tight and the shoes properly adjusted the brakes pumped up as well as Hucks will  10k miles later it's still stopping and holding it's fluid  Good luck Dave | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Went through this. This particular right front junction block is the only junction block that is not reproduced anywhere. You would need to find another original if you want to keep the stock setup.
By the way, the weird stock setup - separate tube for front left, other three wheels through this junction - would have to be changed if you you went with a dual cylinder.
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Nov 2014 Posts: 24 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 24 | Thank you for your recommendations and helpful information.
I will post an update on how the whole job went after I'm done. | | | | | Joined: Nov 2014 Posts: 24 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 24 | Thank you Wurlitzer 46. I was planning to clean-up and re-use the one on the truck now from recommendations made here. A friend of mine also had a spare so we cleaned it up and have it as a backup. After calling many stores and not finding it new - makes sense or confirms what you're saying. Bad news though on this project - I was driving my truck to a friends shop where I was going to re-do the brakes. Truck started vibrating something fierce. Stopped, checked underneath but did not see anything obviously wrong. May be a drive line issue (had a similar issue last year).  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hey guys, this may be what your looking for. It says for the frame rail for the years we want but it doesn't say "exactly" the sizes. A phone call should be in order if needed. The Filling Station http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z510647~P29.50~~~~S4DO12ZH4724158723050V~Z5Z5Z5~Z5Z5Z50000014x
copy link and paste it..
| | | | | Joined: Aug 2014 Posts: 213 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 213 | Here ya go Alvin............ Brake Line Fitting Link
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | As Joe says Alvin, That's the one, Basically a "tee" with a mounting stud to go thru the frame rail. regards and Happy Fathers Day, DADS! steve sr. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hope Panchos54 checks back in. Thanks Joe, don't know what happened when I pasted the link?
.....I just wanted to show those blocks ARE out there. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
Again, thank you for the additional references:
I was able to find what I needed.
Achipmunk - The picture in the link is exactly what I was looking for. In the link and description it excludes my truck as it is 1/2 ton. (1951-55 (1st Series) Truck (except 1/2 ton)
Carolines truck - Thanks for the pictures, those were very helpful.
I have another question. At the end of the master cylinder where the tubes split to go to the left front tire and the other across the frame to the junction block, is that a part that you all recommend be re-used? It didn't come with the master cylinder and I can't seem to find that part either.
Thanks again, | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Hey guys, this may be what your looking for. It says for the frame rail for the years we want but it doesn't say "exactly" the sizes. A phone call should be in order if needed. The Filling Station Brake Line Fitting LinkIt was a while ago and I am a little hazy but I believe I bought one of these junction blocks - same as Jim Carter MEE 247. The vendors list the application as "1951-55 (1st Series) Truck (EXCEPT 1/2 ton)". If I remember, that part has three 1/4" holes, but the stock junction block on the 52 had one 1/4 hole in the center, and two 3/16 holes on the sides. Carolines truck: that is a great modification. What size is the line from the master to the front junction block? Then what size from junction to each front wheel? Pancho: The fitting on the end of the master cylinder is available from the vendors:
