1 members (Otto Skorzeny),
127
Mod | | | Forums66 Topics128,089 Posts1,056,442 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 53 Chevy truck with a 235 engine I have the original oil bath air cleaner does anyone know how u replace the mesh filter ? The air cleaner doesn't look like it comes apart to get it out . | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sal,
Does the original "mesh" look to be unusable? Or, do you want to get away from oil-bath aspect? (just wondering - it's your choice, of course)
I had two of oil-bath filters that had the whole mesh assembly under the cap removed (cut off). You then find a modern element that fits. You could leave some of the outer wall from around the mesh, so that the modern element is not visible. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I removed the mesh from the 235 air cleaner when I got the '48 and put in a Fram. I then topped it off with something from the kitchen, thanks to Mrs. Wally. This was only temporary (for the next 12 years) until I installed the 261. I don't expect anyone else will follow my example but that's OK!! My Early Air Cleaner Setup. - 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2000 Posts: 5,225 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,225 | I have two of the filters like you have. Actually I have three, but one is in real rough shape. I soaked mine in a degreasing solvent tank at work, then a carb cleaning solvent tank, and finally a very strong soap. After all that soaking, I was still getting dry dirt pellets falling out. I finally pulled all the fibers out after removing the baffle on the bottom. You are correct in your observations, these filters do not come apart. Most guy's cut the guts out and install a paper element inside and use the lid to seal the top of the element. I haven't decided how I am going to fix mine yet, but i do know, I wasn't going to get all that fiber material clean. It was full of dried on bits even after all the soaking I did to it. I believe the fibers are cocoa fibers like you would use for a planter from the garden center. Joe
| | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Not trying to hijack the thread, but is it possible to convert from an oil bath air cleaner to a dry filter? And if so, what happens to the hose leading from the canister to the engine?
Today is the best day of my life!!!
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I converted my '38 to a dry element. I have no hose. I'm assuming you have a 'newer' vehicle with an early PCV system?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Carmen,
Let us know the year of your engine and the size of your engine.
Nonetheless, as Tiny posted, if you have a PCV system, just leave the hose in the same place on the air cleaner, if you change to a dry element.
| | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks for the info. Mine is a '54 with the original 235 engine.
| | | | | Joined: May 2013 Posts: 173 Shop Shark | | Shop Shark Joined: May 2013 Posts: 173 | You can just clean it by letting the mesh soak in gasoline and rinse it out...shop manual says do that every 6000 miles | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Deve, thanks for that info. I am going to convert mine Steve | | | | | Joined: Feb 2000 Posts: 5,225 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,225 | While looking for something else, I came across this and posted it for another member. He was looking for information on a 1961 air filter. https://www.gmheritagecenter.com/do...hevrolet-Trucks/1961-Chevrolet-Truck.pdfThis list the truck as having an oil bath air filter, it also list the Thriftmaster as using Cactus fibers, and the Jobmaster as using Pita fibers in the filters. Why would they use different fibers? and what is Pita fiber, ( Pita (Bot) A fiber obtained from the Agave Americana and other related species, -- used for making cordage and paper. Called also pita fiber, and pita thread. ) Joe | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Lots of natural fibers used back then for filters and upholstery stuffing. It was quite versatile and held up well. In the AD seats the fiber pads which are often refereed to as Horse Hair are really coir. A fiber from the coconut husks and still widly used today for mats, brushes and such. Here's a coir pad that was sat on for 60 years and is still in excellent shape: http://www.pbase.com/dennygraham/image/120777683DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2000 Posts: 5,225 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,225 | Where did they get it all? Did GM have there own growers? | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Denny, are these still available? I need to do my bench seat. Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The coir is still being used as I said in mats brushes and stuffing. The rubberized padding is used in restoration of older furniture but it's not quite the same as that used in the truck seats originally. This is some that I bought a few years ago just to see how it compared to the original material. http://www.pbase.com/dennygraham/image/125148167Every upholstery shop that I've heard of subs modern day foams for the coir cushion. But after sitting on the seat that I re-upholstered nearly ten years ago and 16,000 miles back, it's quite comfortable. I've never had a complaint from anyone riding in the truck about the comfort of the seat. I think one of the major reasons these need replacing is that the mice just love to nest in it and the cotton, which of course renders it unusable. dg
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I reworked my oil bath and now I run a K&N filter. From the out side it still looks like oil bath. 53 3100 root | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Denny, that last statement just might steer me away from coir. Mice can easily get into the cab. My cat can;t keep up with them. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Denny how does that "blue stuff" to the original? Steve | | | | | Joined: Jul 2013 Posts: 160 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 160 | I reworked my oil bath and now I run a K&N filter. From the out side it still looks like oil bath. 53 3100 root Can you give some details on this mod, K&N number, etc. | | |
