| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I recently installed, using a Clifford open 4 bbl manifold and adapter, a new(not rebuilt)2G on a modified 261. I want to adjust the feeds using vacuum. Admittedly, I am not up to date on a 2G. Where do I pull the vacuum on it. There are 3 nipples on it. Manual choke. Any help or a lead to help would be appreciated.
Drew
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Usually the dist vacuum advance is taken below the closed throttle plate. This way theres no vacuum advance provided at idle. As the throttle plate begins to open vacuum is then produced to advance the timing to a point where the mechanical advance takes over. Good luck Dave | | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | Below the throttle plate is full manifold vacuum. Above the throttle plate is ported vacuum, which increases as the throttle plate opens.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks guys. I did some more Stovebolt searches and pretty sure I have it figured out. If I don't, " I'll be back."
Drew
