5 members (Gdads51, tclederman, 68ironhead, chemanic, Otto Skorzeny), 102 guests, and 2 robots.
Topics128,101
Posts1,056,339
Members48,441
I have just returned from the Barrie swap meet and I have seen the new style toeboard/floorboard half panels. They didn't have the lip the is normally present at that joint. In addition, they didn't appear to be very heavy either.
1951 1 Ton Completed
But heavier than the toe board or floor panels previously available. At least that is my opinion after seeing both.
I just got a new LMC catalog and was looking at these. I have to admit I am thinking of getting these. They are less expense then buying the toeboard and 2 floor panels. But that is just my 2 cents
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Junior Member
Junior Member
Just finished installing in a 50 chevy. Very satisfied.
I like the idea of the angle being already set. I would think that there is less chance of things ending up a bit out of place.
Anonymous
Unregistered
Anonymous
Unregistered
rimfire - can you tell us about your instalation? Did you happen to take any pictures along the way?
I also just finished installing them in my 53 1/2 ton. I did not use them "whole", but cut what I needed to patch. The corners for the original battery cover had Radii that were too large, thus the cover did not fit right. So I cut around the originals which were still intact.
I was satisfied with the result (It's a driver) and was able to finish with a solid floor. There are some small misc holes missing, but these are easily installed on assembly (most likely a better time for them anyways).
Cheers,
1953 Chevy 1/2 Ton Pickup
