| | | Forums66 Topics128,142 Posts1,056,490 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have just returned from the Barrie swap meet and I have seen the new style toeboard/floorboard half panels. They didn't have the lip the is normally present at that joint. In addition, they didn't appear to be very heavy either. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | But heavier than the toe board or floor panels previously available. At least that is my opinion after seeing both. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I just got a new LMC catalog and was looking at these. I have to admit I am thinking of getting these. They are less expense then buying the toeboard and 2 floor panels. But that is just my 2 cents
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Apr 2003 Posts: 24 Junior Member | | Junior Member Joined: Apr 2003 Posts: 24 | Just finished installing in a 50 chevy. Very satisfied. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I like the idea of the angle being already set. I would think that there is less chance of things ending up a bit out of place. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | rimfire - can you tell us about your instalation? Did you happen to take any pictures along the way? | | | | | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | I also just finished installing them in my 53 1/2 ton. I did not use them "whole", but cut what I needed to patch. The corners for the original battery cover had Radii that were too large, thus the cover did not fit right. So I cut around the originals which were still intact. I was satisfied with the result (It's a driver) and was able to finish with a solid floor. There are some small misc holes missing, but these are easily installed on assembly (most likely a better time for them anyways).
Cheers, 1953 Chevy 1/2 Ton Pickup | | |
