0 members (),
51
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Again, thanks for posting your photo journal. I wish you'd get a 55 2nd series and work on it! That'd be most convenient; for me anyway  Brad Wrench Fetcher, PhD | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Hang in there Brad. With natural shrinkage, your factory original gaps will appear soon enough so that you will not be deducted by the AACA judges for not having a bit of the roof showing.  Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Looks real nice Brad. Love the Blue, but I gotta admit, I've never been a fan of the red trim, but........ Did you have the windlace already in place? And is the difference in the early center 'Z' cleat that it is part of the center bow? I haven't had my headliner down but it appears that there is now inner bow, only the 'Z'cleat, is that correct? So, what difference would that make in the fit of the two cardboard pieces? tks dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Denny, The bow here is not a Z like the '50 would use. It is a U shape with 7 screws in it over its length. It works by squeezing the back cardboard under a flat edge and the front slides into the U. As for the cardboard it is completely different with slots in it to clear the screws on the various surfaces including the door weatherstrip. I believe it is these slots that give it enough extra length on the sides. I had my weatherstrip in, I just trimmed and tucked during the final fit, basically trimming off the slotted holes on the sides. https://www.flickr.com/photos/advance-design_parts_co/18614309870/in/album-72157631867396207/I did this install before with the Z type trim and corresponding headliner and I was not happy with the results. So I cut (spot welded in) the top bow set out of a parts truck and to Chevrolets credit it is a better set-up but would have added to production costs. This cardboard set was just weighted to straighten them, I did not use any spray formula to mold them as has been described in previous posts here on the bolt. | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Looks good Brad. That is the last item I have to install on my 47 GMC. I have been putting it off because of all the horror stories on fitment. Maybe his fall, I will get Denny to come over and help me!
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You got it Bruce.
Thanks Brad, always learning, wish I had a few dozen run thru the barn like you've had, great for documenting the slight differences. Always thought that wetting down the cardboard was a bad idea, had to be a better way. I still think the cardboard was installed at the factory before they ran or installed the windlace, that seems as though it would make it a snap. I've had two sets of the cardboard liners laid out flat between two sheets of cardboard for several years now. They should be flat by the time I'm ready to install them, if the mice don't get to them before then.
dg
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Nice job Ssrjim. The pictures and text will be very helpful when I get to it. Steve | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It do look good Jim, that headliner. If they were so hard to install them the factory would have used something else. And as I've been saying for years, they would have put the headliner in at the factory before the production line got to the station where they put the windlace in. It's my guess that's the mistake the guys are making and why they are having so much trouble installing them. Speaking of windlace, I've been looking at them whenever I see an AD at a show and most of them that have the original windlace replace have a pucker or buckle in the upper rear corner. Apparently the reproduction rubber is compounded to hard and it can't make the bend. The original conformed to the radius very nicely: http://www.pbase.com/dennygraham/image/160622906 dg
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I'll bet there is a trick, heat gun perhaps? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Since the windlace is such an important part of installing a new headliner I'd like to offer my thoughts about that part of the job. I'm pretty sure the original windlace was natural rubber and the reproductions that we're being sold are urethane. When it comes to urethane it all depends on where the compound falls on the Shore 'A' durometer scale. Seems like the different colored windlace's are from different suppiers and they are compounding them differently. I've seen some that you had to fold to get around the corner and others that 'almost' made the curve. But have yet to see one of the reproductions that makes a smooth bend like the original parts.
Denny G
