4 members (greenie-reddy, pauld, 2 invisible),
85
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11079 03/26/2002 7:10 AM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | I managed to obtain one of those double action fuel pumps, the ones that have the vacume pump in addition to the fuel pump, for my '54, just so my wipers will work consistantly. My question is how does the vacume line hook up? Of course there was no instructions included with it and my assembly manual, (which I now can't find...must be in the garage) only says that a line comes from the manafold and the other goes to the wiper motor. This seems pertty basic but just so I don't mess it up I want to confirm that this means that the vacume line coming from the manafold that normally goes stright to the wiper motor will now run to the vacume pump on the DA fuel pump and then a line from the DA fuel pump to the wiper motor? Thanks for the help!  | | |
#11080 03/26/2002 4:10 PM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | I hooked the vacuum side on the fuel pump to the wiper motor and the outlet side on the fuel pump to the manifold. That way the manifold is working as a fore-pump for the fuel pump. I also oiled the wiper motor. They work great. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#11081 03/26/2002 10:55 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Hey 54; Don't sweat it. I put one on my '49 GMC and like Wally said,it works great. As mentioned, take the hose from your manifold to one side of the DA pump. You can tell which side it should be on by hand actuating the pump lever. The side that sucks is the inlet and the side that blows is the outlet. Take the outlet to the wiper motor. If you get them reversed, you'll be able to tell. | | |
#11082 03/26/2002 11:15 PM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | My double-acting fuel pump actually had the ports marked (wiper and manifold). Are there many brands and designs for these? I hope it works. Good luck with ya'lls. Terry '53 1/2 ton Blue | | |
