1 members (JeffA), 162 guests, and 3 robots.
Topics128,162
Posts1,056,938
Members48,458
Checked in the shop manual and cannot find an answer...
Is there a torque setting for tightening the two bolts on the thermostat housing after replacing both the thermostat and a new seal?
Most old shop manuals have torque specs and or a chart covering a general torque per size of bolt. I wouldn't be to concerned with torque on this part, just use some gasket sealer and make them tight with a not to long wrench. Also put some thread sealer on these bolt that go into water passage.
1946 1/2-Ton Chevy
Ex Hall Monitor
Ex Hall Monitor
Torque specs for the most part are not in the repair manual. That frustrates me as well. Sound advise above. Use gasket sealer and get'em good & snug. I don't think I've ever used a torque spec on a thermostat housing.
Thermostat housing bolts/screws: 25-35 ft-lbs
From 1960 Truck Shop Manual, Engine Section on-line
Thanks all...I appreciate the knowledgeable replies both past and future.
Tim
I found the 25-35 Ft pds information in a section for Chevy small blocks. I wonder if that can be applied to an older 216 stove bolt with cast iron thermostat housing?
Originally Posted by Darling
Thanks all...
That is the same type of housing used in 1960 - the year of the sheet that I posted a link-to, above.
Here is the torque-specs page.
Grandpa always said to "stop tightening well before it starts getting looser". But then he also was known to say, "tighten it as tight as you can, plus 1/4 turn".
25-35# sounds right to me.
Carl
Gas Pumper
Gas Pumper
My Grandpa always said "Don't take any wooden nickels". I have NO idea, but I just use my 25-30# calibrated hand. But the specs are very handy to have for a really well done engine.
That is the WHOLE reason why I go strictly by the specs using my $9.95 Harbor Freight Torque Wrench! LOL!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Do not underestimate that HF torque wrench. Several years ago, I found an auto-engineering website that checked the calibration of a newly-calibrated Snap-On torque-wrench against a newly bought HF torque wrench. The HF wrench was as close to the correct torque (over a range of torques) as was the Snap-On wrench.
I did own test comparison with a friend's newly calibrated torque wrench compared to my never calibrated (but, rarely used) HF torque wrench. My wrench was +/- within 5% of the Snap-On wrench (over a range torque settings.
I tighten to the specs, if I have them.
Thanks to all
