0 members (),
118
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | I bought handles that are splined and find I need em square......guessing that the door latches I have are not 1940. But........one of the square posts for the inside handle is missing. Note sure if its broken off or missing all together. Is there any way to make something? Does anyone have 2 square connection door handles for my 1940- need not be perfect! Also notice the handles are loose, and sometimes can open on their own. Is there a gasket or piece that should be mounted with these handles that keeps them taunt? Thanks, George in Tallahassee | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Since perfection is not required I'd either build them up with the mig or even JB weld, if they need to grow or file them down from where they are.
| | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | I will deal with the square holes on a round peg somehow, but I am still MISSING COMPLETELY the sq post on one of the latches. It looks like it waw swedged onto the latch. Is this part available to buy or even make? instead of buying a new latch? | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | The driver's latch has a square post for the small inside handle. None for the passenger. Not sure if that is what you are referring to as the 'square post'.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | Now I understand that I am missing the sq post mechanism- and I guess the rod that operates the latch. So you say this is only present on the drivers side- how do you get out of the pass side? Would anyone have this part on the forum? Used hopefully. I also need two of the outside door handle springs that keep them from flopping. Is this spring something that that could be made with a normal spring and some plyers? George [email protected] | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Hey George, Yeah kinda odd about the door locking. You can have some interesting trivia reading by searching this site on it. The springs are available from the vendors. You might want to place an add in the parts wanted forum.
Dennis
40 Chevy 1/2 ton
