| | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Now I know what a sardine feels like in those cans! I am 6'5" and 320 pounds (no wise cracks I already lost 45lbs.with more to go). Are there any ideas or mods to tweek out more interior space? I have already had seats redone with thinner sponge and also will curve floor shifter away from me. Any ideas out there?? John. | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | My grandson is 6'2" 300lbs.He can't fit in my 51 3100 good enough to drive it. On the other hand I love the size.I am 5'4" 150lbs.And for once I can drive without a cushion to give me more height on the seat.---Jack | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Crap! No wise cracks allowed! Congratulations on losing the 45. Only advice I can offer is to consider a Task Force truck. Carl
| | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Thanks Carl, I have a 50 Chev 5 window which I can't wait too drive once the resto is finished. But it is sure short on interior space. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Without knowing what your truck actually is, if there is a fuel tank behind the seat, remove it and replace with a frame mount tank. You'll gain a lot more leg room. Also go to moveable mount seats, like bucket seats.
Drew
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | One way to fix it, is to shorten the column and shaft about 2 inches. i saw one at a show and i could not figure out what was different about the truck. the owner said all he did was shorten the column and steering shaft 2 inches. he was at lest 6 ft 4 in and about 275. root good luck | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I replaced my original seat with the plainest seat you can get out of a '95ish Chevy work truck (W/T) and can now sit with my left leg STRAIGHT out with my foot next to the dimmer switch. I'm only 6'0" but I felt so crowded in my truck before the switch. Now I straighten my arm out to grab the choke knob and there's lots of room over my head. It fits perfect with the gas tank still in the cab. In fact If I removed the tank I would gain nothing.
Also, as root says, shorten the steering column, a couple inches would make a big difference.
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I don't think you can get any less dish than you get with a '50 steering wheel. | | |
