1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | what do you use to hold the door window channels in beside screws? RTV or door rubber sealant or ??? 53 3100 root | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I used 3M Weatherstrip adhesive in areas I could not get a small screw into. I have 5 seasons on the weatherstrip and it has never come loose. I have 5 small screws in the area above the center line. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | In certain areas around the window the metal is 2 ply or reinforced on ths inside. I was able to drill and tap for a 6 or 8 size screw (like a chassi screw from a video cam or player). They are short enough to not poke through yet hold and more importantly hide.
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | thanks brad and caso I planned on using #3 screws and weatherstrip adhesive. a friend said he used polyurethane sealant on his and its been 7 years now so i think i will use screws and poly. 53 3100 root | | |
