1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I have seen some 2 and 3 carb manifolds in catalogs and 2 piece exhaust headers.
It has made me wonder if anyone has done that to a 216.
How much did those parts effect HP, MPG, acceleration, top speed?
And last how did running dual exhausts sound?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Exhaust is throaty and sweet. Speed parts on a 216 are eye candy.
Not much in the 216 for hp gains with those add ons.
Drew
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Ditto- - - - -looks OK, runs terrible! The dual exhaust scavenging makes the carb(s) run lean and the loss of exhaust heat under the intake makes the engine cold-natured and almost impossible to tune. If you're building a trailer queen for the car show circuit, go for it- - - -otherwise, run away- - - -far, far away! Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I don't know, I am using the set up from Langdons, and it runs quite well, I do have higher compression, and an RV style cam. I also used water heat. But it runs just fine. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I don't know, I am using the set up from Langdons, and it runs quite well, I do have higher compression, and an RV style cam. I also used water heat. But it runs just fine. Yes the manifolds I have seen allow for the intake to still be heated. Though it is my son's truck and he has no desire to put any "speed" parts on the truck. Though I did hear some 216's on YouTube with dual exhaust and they sounded nice though it was not given/clear what other engine mods were done. | | |
