4 members (Otto Skorzeny, Rexville48, Gdads51, 59 fleet), 133 guests, and 2 robots.
Topics128,070
Posts1,055,896
Members48,428
#1106648 06/05/2015 11:43 PM
After an engine rebuild,how long can it sit before using it(running it).will gaskets,seals etc. go dry in a years time? This is on a 235,but all engins will qualify i imagine.
3B Offline
Hy Midpiner, If the engine was assembled correctly with some lube on the seals then everything should be fine providing the engine is stored with all of its openings plugged and not out in the rain, hope that helps.
Yes ,that answers my question. The truck wont be done for a while(year or so,maybe less).It would be installed in the chassis,just not running.It is in my shop,indoors.
The '59 235 in my 51 half ton sat for 30 years after a rebuild and all it needed was an oil change and fuel system overhaul. ---Jack
Had my V8 for the 37 on an engine stand for over a year. A couple times a month I'd spin the engine over a little to keep the tension off the same valve springs for an extended period. I probably was going over kill but I am known to do that occasionally. Like CJSTP said, I have also seen engines sit for long periods of time and be just fine.
One of the funniest questions: "I just bought this old car and it seems to run OK. Should I take it apart to replace the gaskets?"
if it ain't broke, don't fix it!
1959 3100 Apache Fleetside
