0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#1106647 06/05/2015 11:06 PM
7
7 Offline
Now I know what a sardine feels like in those cans!
I am 6'5" and 320 pounds (no wise cracks I already lost 45lbs.with more to go).
Are there any ideas or mods to tweek out more interior space? I have already had seats redone with thinner sponge and also will curve floor shifter away from me.
Any ideas out there??
John.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
7998 #1106652 06/06/2015 12:21 AM
My grandson is 6'2" 300lbs.He can't fit in my 51 3100 good enough to drive it.
On the other hand I love the size.I am 5'4" 150lbs.And for once I can drive without a cushion to give me more height on the seat.---Jack
7998 #1106674 06/06/2015 2:14 AM
Crap! No wise cracks allowed!
Congratulations on losing the 45.
Only advice I can offer is to consider a Task Force truck.
Carl
7998 #1106695 06/06/2015 3:35 AM
7
7 Offline
Thanks Carl, I have a 50 Chev 5 window which I can't wait too drive once the resto is finished. But it is sure short on interior space.
All Original
7998 #1106735 06/06/2015 2:03 PM
Without knowing what your truck actually is, if there is a fuel tank behind the seat, remove it and replace with a frame mount tank. You'll gain a lot more leg room. Also go to moveable mount seats, like bucket seats.
Drew
7998 #1107415 06/09/2015 11:38 PM
One way to fix it, is to shorten the column and shaft about 2 inches. i saw one at a show and i could not figure out what was different about the truck. the owner said all he did was shorten the column and steering shaft 2 inches. he was at lest 6 ft 4 in and about 275. root good luck
7998 #1108314 06/15/2015 3:16 AM
I replaced my original seat with the plainest seat you can get out of a '95ish Chevy work truck (W/T) and can now sit with my left leg STRAIGHT out with my foot next to the dimmer switch. I'm only 6'0" but I felt so crowded in my truck before the switch. Now I straighten my arm out to grab the choke knob and there's lots of room over my head. It fits perfect with the gas tank still in the cab. In fact If I removed the tank I would gain nothing.
Also, as root says, shorten the steering column, a couple inches would make a big difference.
root #1108365 06/15/2015 1:04 PM
Rather than shortening the column you might want to consider a steering wheel with less dish. I did this on my '65, replaced the stock wheel with a Grant #992 steering wheel.
Hope this helps. thumbs_up
http://i645.photobucket.com/albums/...Status%20Photos/GEDC1238_zps6cfb736b.jpg
7998 #1108368 06/15/2015 1:17 PM
I don't think you can get any less dish than you get with a '50 steering wheel.
Moderated by  ndkid275, Phak1
