| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | Truck: 1937 1/2T Current Set-up: Engine: '51 216, bell housing has mount for master cylinder and pedals but missing hole for left bracket for the stomp starter. Not sure what transmission in is there.
New Engine: '59 235
I have read the tech tip and still have a few questions.
It appears that I will need to change or modify the front mount plate, correct?
If I understand correctly, if I use the '59 flywheel, clutch and bellhousing - I will have to solve the mounting problem for the master cylinder / pedal bracket. Does that sound correct? Any other problems with using the newer items?
It also appears that I will have to modify or change the water pump pulley, correct?
Other than new motor mounts and using the 216 inlet for the coolant, am I missing anything else?
Thanks for your time, Justin | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Using a 1938-47 truck bellhousing will allow you to use the original trans and clutch/brake mount. Using a later bellhousing opens a can of worms. Timing plate will most likely need drilling for front mount. Water pump will need attention.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Alot of these issues are outlined in my project article. The water pump part of this will be outlined soon. Keep the old bell housing, flywheel, and starter. The water pump will be done right so you have your fan centered on the radiator as it was with the 216. Thanks to Dave! http://devestechnet.com/Home/Project1959235 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1937 was the last year to use a carbon throwout bearing. The flywheel, starter, clutch, pressure plate, and even the bellhousing will not work. Chev changed the position of the pivot for the clutch fork with the new ball bearing design starting in 1938.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Listen to Dave, not me when it comes to most everything pertaining to these older vintages! You already knew that!  | | |
