Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Bill Marlow, Otto Skorzeny, baldeagle, EchoBravoSierra, Jon G, Jeff Ogden), 38 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#1106292 06/04/2015 1:27 AM
How much clearance is needed between the splash apron and the back of the cab?
1954 3/4 long box.
[IMG]http://i86.photobucket.com/albums/k83/DiAdogger/100_7379_zpsvpqmrlkx.jpg[/IMG]
Thanks.
Ken
Kennyjr #1106299 06/04/2015 1:55 AM
Let's see if someone in 'Beds' can answer that.
Kennyjr #1106829 06/07/2015 12:55 AM
I guess not, cletis.
Maybe body and paint would be a better place?
Personally, I rarely visit the bed forum.
Carl
Kennyjr #1107449 06/10/2015 3:12 AM
Sorry Kennyjr. You have been cletis'ed to nowhere land.
Kennyjr #1107545 06/10/2015 5:31 PM
My bed, sitting on all new blocks and hardware, leveled and squared measures the following. In the center of the cab to my bed panel 1-1/8" (narrowest point with curve of cab). On the aprons to cab the narrowest point near the top of the apron is 5/8" clearance. If your bed is square and fenders correctly positioned it should be near these measurements. The clearance in your photo is too tight the normal flex is going to cause contact at those surfaces and mar your paint. I should add my truck is a frame-off so all mounts and related hardware is brand new, hope this helps.
Brad Allen #1108322 06/15/2015 4:08 AM
Mine too is a frame off, my buddy started it and I am finishing it hence the reason I am not too sure of some things.
Brad I have started another post here
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1108320#Post1108320
If you could add anything I would appreciate it.
Thanks.
Ken
Kennyjr #1108343 06/15/2015 6:40 AM
Sorry Kenny I never post or respond there. Here is my answer to the question.
It would seem that cab adjustment if standard mounts are used and the cab floor is correct would be the hardest fix. You have multiple fit issues with column, shifter, pedals, brake linkages, etc. The front cab mounts are ridgid points with no fore/aft adjustment only height. If you need to gain 5/8" as shown from your picture I would get it on the bed end.
https://www.flickr.com/photos/advance-design_parts_co/12315088635/in/album-72157640522200463/
