Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (1955 1 Series, Dennys28, baldeagle, tclederman), 44 guests, and 2 robots.
Topics128,004
Posts1,055,265
Members48,418
#1106227 06/03/2015 6:37 PM
Whats the difference between a AD 1/2 ton1947-50 spindle with huck brakes vs 1951-54 spindle with bendix brakes? I thought they were different , just happen to have a set of each at the same time and dont see anything different. Thank for the help
oldblue48 #1106237 06/03/2015 7:30 PM
Check the diameter and location of the bolt holes?
oldblue48 #1106264 06/03/2015 10:52 PM
The lower two bolt holes are drilled for 7/16" bolts up to 1950. 1951-59 are drilled for 1/2" bolts. You can drill out the earlier spindles and use them.
My Blog
oldblue48 #1106268 06/03/2015 11:04 PM
Ah hah. So what year up to 1950 is the early spindle?
oldblue48 #1106288 06/04/2015 1:07 AM
1941 started the larger king pin size, used through 1959.
1941-50 are the early style used with Huck brakes.
When Chev went to Bendix brakes in 1951 they increased the lower bolt size.
My Blog
