| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | recently replaced my original 216 with a 235 from a 61 impala. Rebuilt the Rochester carb, and everything seems to be running fine, starts great drives out well, no complaints so I decided to check for gas milage since my gas gauge isn't working. I put the 235 into my 49 pickup, I still have original gas tank behind seat. It took 13.4 gallons to fill it up. now I am looking at 6 mpg, should gas milage be that bad? I was figuring maybe 10-12, but 6? I have noticed a slight leak, just enough to get your finger damp at the fuel pump fitting going from tank to fuel pump. Do you guys figure I will just have to live with this bad mpg or is there something I need to look at doing. By the way, I am using non-ethanol gas at 93% is that over-kill or necessary for the older engines. Sure would appreciate some help on this one. Thanks for any intrest an suggestions | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Pull the spark plugs. If you are dumping unburned fuel (bad carb)out of the tail pipe, the plugs will be extremely sooty.
| | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Red
Can I ask what your rear end gearing might be?? Also what size tires are you running? I am curious as I am waist deep in a rebuild of one of these trucks and I am really wondering how bad these things are as far as mpg's go...I am hoping someone on here can shed some light on that terrible 6 mpg number...
If mine is that bad also...I will be selling mine..
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Thats not good. My 49 w/a 216 avg's 12 to 13 w/stock 4.11 gearing.
Someone may have changed out the main jet with something bigger (stock would be a 58) or perhaps the choke isn't opening up enough. Course no matter the cause you should be seeing black smoke and soot on the plugs if it]s running to rich.
A sbeen said check the plugs good luck Dave | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It should get better mileage then that. The power valve on the model B roch. is hard to get correct. First make sure the hole in the bottom of the carb has a passage to the vacuum in the intake manifold. Make sure the power valve piston goes in the hole & knocks the ball off the seat. Make sure the vacuum advance is working. You should be able to see the dist turn at part throttle. Try advanceing the timing about 5 degrees above the spec. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Perhaps your fuel line leak is larger than you think and contributing to the poor mileage. Also, you say you are using non ethanol gas at 93%. If you mean 93 octane, I don't think that is necessarily good. These engines are low compression and may not burn that fuel very well. I don't know whether that would contribute to poor gas mileage but at least it is a waste of $$. Could you clarify what you meant by the type of gas? For comparison, I get 12 mpg with my unloaded '50 COE with a later 1958 235, up and down mountain roads. Kent | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | I usually get around 17 mpg, with a 235 and a Carter carburetor. Driveline is stock enclosed driveshaft with 16 inch tires, and 4.11 rear gear. Don/RdsLessTaken http://s1291.photobucket.com/user/RdLessTaken/library/ | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | My stock 52 3100 got 15.0 MPG empty, and 15.0 MPG with a 3/4 ton pallet of potash in the bed. You have something seriously wrong somewhere. Tire diameter way smaller than stock? Odometer? Measurement of fuel used during your test is wrong? Calculation error? I am hoping its one of those. They are easier to "fix. Carl
| | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Check that carb base gasket first. If the hole in the bottom of the carb base is blocked off, that means the power valve is open all the time | | |
