5 members (rfs56trk, Gdads51, 2-Ton, 78buckshot, 1 invisible), 180 guests, and 4 robots.
Topics128,078
Posts1,056,024
Members48,433
#1105418 05/29/2015 5:12 PM
mj
Offline
should a 1954 235cu motor use solid exhaust manifold studs, or the ones with the springs on them ?????it is the original single pipe exhaust.
mj #1105476 05/30/2015 12:49 AM
Crusing in the Passing Lane
Solid, Cu nuts work fine, that is on the manifold, no personal requirements implied.
Gas Pumper
Gas Pumper
yup.. just everyday studs and nuts. I got my replacement ones for the 235 at NAPA. I think the studs are black plated regular steel but Copper/Brass/Tin Nuts. Like Ed said for sure.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
