| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I'm finally putting the finishing touches on my '42 and went to assemble the trim around the doors and realized there is a small gap between the two pieces that go up the side and over the top of the doors. There is a small 1/4" gap with a screw hole so I'm assuming I'm missing two pieces of trim. Any idea if that's a fact and where I might be able to find those pieces? | | | | | Joined: Sep 2010 Posts: 1,708 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,708 | Yes there should be a small piece of trim to span the gap. I don't know if anyone sells these. The piece is easy to make with a pair of tin snips. Then shape it with a vice and pliers to match the other parts. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | This is from my '40 but should be the same. pic1 pic2 pic3 Dennis
40 Chevy 1/2 ton
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | This to me to be the same as the piece that joins the sections of trim that go across the top of the door interior. I seem to remember seeing them for sale in one of the catalogs - Chev's of the 40's, Filling Station, Jin Carter.
Bob
BobS46
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I found the part that I had seen before - Jim Carter p/n TRC146 - window trim clip. Looks very much like the pics that Dennis had posted.
Bob
BobS46
| | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Thanks Guys for the pics and part #. Looks simple enough to make. | | |
