4 members (Rich'sToys, Bill Hanlon, klhansen, 1 invisible), 55 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
I have ordered 215/85R16 tires and now need to order wheels for my '53 3100.
I will need 5 on 4.75 bolt pattern and 16's. I am thinking of 6" wide but not sure of back spacing. Any ideas on back spacing and/or width would be appreciated. thanks ralph
Ralph
All gave some - some gave all" -- A veteran is someone who, at one point in his life wrote a check made payable to the United States of America for an amount of "up to and including his life."
JDeereGn #1104363 05/23/2015 3:02 PM
JDeereGn #1104402 05/23/2015 7:42 PM
Need more information. What kind of frontend are you running? Rear axle width? Those will come into play. You're good on the 6" width, 7" would be ok, too. The offset and the backspacing will vary depending on width and application.
Bill Burmeister
JDeereGn #1104827 05/26/2015 1:53 AM
Thanks guys. Offset is what I am concerned about. Gonna run S10 4x4 rear axle which is 59" outside of drum to outside of drum. Gonna use billet spacers to widen front to the same 59". Del at Wheelmith suggested 3.5" back space/offset but he wanted me to double check. My cab and bed aren't mounted yet so I need help with dimensions. Will I be OK with a 6" wheel with 3.5" backspace/offset? thanks ralph
Ralph
JDeereGn #1104833 05/26/2015 2:08 AM
3.5" should be fine. You didn't mention what front end you're using, how much narrower is it from the rear axle? You mention using spacers, that always concerns me, especially when they're used on the front. How much of a spacer are you going to use? You will want make sure the studs are long enough. Anything too much, you'll want the spacers that bolt on and have a second set of studs that the wheels bolt, as getting too long with the studs can cause stress to them. Also bear in mind, spacing the wheels out will alter the scrub radius as wheel as the wheel centerline on the bearings. You may experience some handling issues, nothing major, though, and you will want to pay attention to the wheel bearings for wear/play.
Bill Burmeister
JDeereGn #1104839 05/26/2015 2:21 AM
Thanks LONGBOX55 Front is standard 2WD S10/Jimmy. I intend to use 1 1/2 or 2" spacers. They will most definitely be the kind with their own studs. When I get wheels and tires on rear I will see if I need 1 1/2 or 2" to bring front out to match rear. This is my first AD project so I very much appreciate all the help I can get. I will order wheels tonight Thanks a lot ralph
Ralph
JDeereGn #1104919 05/26/2015 4:17 PM
a 15x8" with 3.5" Backspace will fit inside the front fenders without spacers on either a '52 or '46 that is mounted on an S-10 frame. It depends on the look you want though, a 6" wheel with 3.5" backspace seems tucked in, but then you're talking about using spacers. It might be well advised to wait until your sheetmetal is mounted.
My 46 GMC on Photobucket
