0 members (), 108 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1104454 05/24/2015 1:53 AM
On my front turn signals, the right one works great but the left one starts to light up but takes about 2 seconds before it will flash. I have checked all the wires and grounds on both and they all good,put in new flasher solinod still does the same. Could it be the contact in the flasher unit on the column or ??? 53 3100 root
root #1104478 05/24/2015 4:00 AM
3B Offline
Hy root, is the left rear turn signal working? A lot of the older flashers are load reactive and require multiple bulbs to flash properly, hope that helps.
root #1104577 05/24/2015 9:05 PM
Yes, the rear one works, it LED but it flashes at the same time as the front. I have tried using a flasher solenoid for LED's, then no flashers at all. 53 3100 root
root #1104659 05/25/2015 5:29 AM
Do you have LED bulbs's on all four corners? I just want to make sure we are comparing apples to apples. If one side has LED and the other dosen't there will be a different flash rate due to different amp load at the flasher.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
root #1104679 05/25/2015 1:32 PM
Root, I'm guessing that you have switched to a 12 volt system, since your using LED's? I still operate with a 6 volt system and used a step up transformer for the signals and just the rear running lights. I also use an incondensent bulb for the front fender lamps. Are your rear turn signals stand alone or are they incorporated with the brake lights? Did you try using an electronic flasher? They are not load dependent to operate properly. Get back with all the information possible so everyone can make a better assessment of your situation. Take care and have a great Memorial Day! Jim (aka 53 green 1- ton)
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
root #1104732 05/25/2015 6:32 PM
12V The front are incandescent and the rear are LED's and yes they are tied into the brake lights. Yes, I have tried electronic flasher and then nothing works at all and I grounded the flasher, so reinstalled the old flasher and everything works except the left flasher as stated above. I also have a separate ground on the front turn lights. Don't know what else is needed. 53 3100 root
root #1104734 05/25/2015 6:45 PM
Root just sent you a pm
In the DITY Gallery
root #1104972 05/26/2015 9:55 PM
53 green never got your PM Randy
root #1104986 05/26/2015 10:57 PM
Randy, it's not the first time for that. Working from the phone. I'll resend, jim
In the DITY Gallery
root #1105329 05/29/2015 2:04 AM
Is the bulb in the left turn signal exactly the same as the one on the right? Have you tried replacing them even if it is? Do you have seperate flashers for the left and right hand side? if so are they identical or have you swapped with each other to see if the problem follows the flasher? If you suspect the column unit change the wire so the left is coming from the RH wire and the right is coming from the LH wire. If it's the column unit the problem will now be on the RH bulb. If not then the column unit is fine.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
root #1105343 05/29/2015 3:04 AM
In past rewires and transition to LED bulbs had almost always shown issues with a mechanical flasher. The solution was always adding a load resistor in parallel to the LED. This brought the current up to expected levels.
I have not looked lately but few years back you would find them next to the LED bulbs in the auto parts store.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
root #1105351 05/29/2015 3:49 AM
I'm going to agree with bztguy, that should narrow down the source of the problem.
Also, I switched my rear lights from incandescent to LEDs and left the fronts incandescent and have had no problems. in fact, the front turn signals seem to be a bit brighter. I changed the rear lights and nothing else.
root #1108530 06/16/2015 2:24 AM
Randy. Glad to hear that you have the signals figured out! Good luck on the home front issues. Take care
Jim
In the DITY Gallery
