0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 16 New Guy | | New Guy Joined: Mar 2015 Posts: 16 | My outlet no longer functions. I need to take it out, clean the rust out, and determine if I can make it functional or need to replace it.
However, I cannot figure out how it might come out of the dash. There doesn't seem to be a nut on the back side, but there seems interference in moving either direction.
Any suggestions? | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Most of those the outer shell screws off. Hold the front from spinning and reach under and twist off the back. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Man, you are a video producing machine! Nice job, plain & simple.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks The new iPhone 6 I have makes it easy and fast
I made that video for another member a while back that had the same question.
Just adds to the good description given above
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Gus I agree, one great way to answer a question. Try writing it and we'd end up with five pages of text and some guys still wouldn't get the point. What are you using for a camera mount? And what program do you use for the fade in/out feature, nice touch?
I'm still agonizing over spending the few hundred on a GoPro. I could sure use it to help analyze the tire/suspension/shock problem that's been buggin' me since day one.
Get an I-phone??? Na, can't afford the monthly bills, rather buy a few more sheets of plasterboard for the shop. Priorities you know!
dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | For that one I just used the program that came with the phone. iMovie You can add text, fade and stock music The mount I use most the time is a small tripod. Less than 10 dollars on amazon. The holder is the belt clip for the phone that I put a 1/4 20 coupling nut and screw on. Cut open a window for the lens with a Dreme tooll ...link... Most the movies in my signature line I used a video program call Magix on the computer. | | | | | Joined: Mar 2015 Posts: 16 New Guy | | New Guy Joined: Mar 2015 Posts: 16 | That video sure is helpful. I'll admit a text explanation would have only gotten me halfway there. Mine is so rusted together, that without knowing which piece is on which half, and where the threaded section is, I would have just pulled and twisted to no avail. I can pause the video and look at exactly how the sections come apart.
Now I've got mine soaking with some penetrating lubricant for another go at separating them shortly.
Thanks! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | That Demo is a new, reproduction | | | | | Joined: Mar 2015 Posts: 16 New Guy | | New Guy Joined: Mar 2015 Posts: 16 | Where from? I may need to be acquiring one. I don't think mine is coming apart with out destruction. I can't get a successful purchase on the front trim to get the right amount of torque on the back. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You can get lighter sockets at about any auto parts house.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Having parted a lot of AD's one that can't or won't come apart is common as the behind the dash area seems very prone to condensation and drainage issues. I am out of the country right now but returning soon, if you send me a PM I think I have 6-7 originals around the work bench and I will send you one. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | He didn't specify a year. The video showed what looks to be a plain old universal socket. I've put tons of them in over the years and they all looked & installed like that one. I didn't know a '57 truck would be any different. Is it? Does it work differently?
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | As far as usefulness of the lighter, you can get inserts for it that have USB for charging your phone. (if its 12v)
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The TF trucks (55-59) are just like the video, the back shell screws on to the front half...nothing unique about them. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Local FLAPS will have them. The whole thing can be had for a few dollars. Here is just a sample of what you can get. http://www.autozone.com/lighters/universal-cigarette-lighterThe "handle" bit screws on and off. So you can keep the stock looking one if you like.
Steve H
