3 members (David Bush, GRNHydra, Leo), 69 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
#110417 05/02/2002 4:34 AM
i am restoring my truck (well duh) and i need some welding gear. does anyone have any suggestions? like maybe a miller wire welder or maybe a gas outfit i dont realy know any help would be awesome Thanks
Hudson
#110418 05/02/2002 7:39 AM
Have you checked out the tool forum? cool
#110419 05/03/2002 2:09 AM
no did not occur to me thanks
Hudson
#110420 05/03/2002 6:28 PM
my50trk,
A gas outfit can:
weld
cut
braze
heat stuck nuts, bolts, king pins, etc.
A wire-feed outfit can:
weld
A wire-feed outfit is easier to use on sheet metal than a gas welder. It also heats the metal less, leading to less warpage. However, with a gas outfit, you can braze your sheet metal. IMO, brazing is easier than MIG. It makes a nice seam, and heats the metal even less than MIG does. The bond is not as strong as a weld, but, if done correctly, it is still stronger than the metal itself.
If you can only get one, I would recommend the gas outfit for its diversity and infinite usefulness.
Please note that we have this discussion on a quarterly basis here on this site, and there are a lot of folks here who would recommend the opposite.
Hope that helps some,
Ed
#110421 05/03/2002 8:48 PM
This gets discussed alot...In my shop we run wire and gas, I guess that I would recomend a wire feed, like a little Hobart Handler or a Miller 135 especialy if you are new to welding and if you are not using it for much except sheet welding.
Just my 2 cents...
Good luck!
A guy, his dog and a truck..
#110422 05/08/2002 2:38 PM
In this forum look at a thread called "patch panel welding". It has some great information.
