8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 42 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 42 | i am restoring my truck (well duh) and i need some welding gear. does anyone have any suggestions? like maybe a miller wire welder or maybe a gas outfit i dont realy know any help would be awesome Thanks Hudson | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you checked out the tool forum?
| | | | | Joined: Apr 2002 Posts: 42 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 42 | no did not occur to me thanks Hudson | | | | | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | my50trk,
A gas outfit can: weld cut braze heat stuck nuts, bolts, king pins, etc.
A wire-feed outfit can: weld
A wire-feed outfit is easier to use on sheet metal than a gas welder. It also heats the metal less, leading to less warpage. However, with a gas outfit, you can braze your sheet metal. IMO, brazing is easier than MIG. It makes a nice seam, and heats the metal even less than MIG does. The bond is not as strong as a weld, but, if done correctly, it is still stronger than the metal itself.
If you can only get one, I would recommend the gas outfit for its diversity and infinite usefulness.
Please note that we have this discussion on a quarterly basis here on this site, and there are a lot of folks here who would recommend the opposite.
Hope that helps some, Ed | | | | | Joined: Feb 2001 Posts: 6 Member | | Member Joined: Feb 2001 Posts: 6 | This gets discussed alot...In my shop we run wire and gas, I guess that I would recomend a wire feed, like a little Hobart Handler or a Miller 135 especialy if you are new to welding and if you are not using it for much except sheet welding.
Just my 2 cents...
Good luck!
A guy, his dog and a truck..
| | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | In this forum look at a thread called "patch panel welding". It has some great information. | | |
