5 members (dt235sd, Hush, Rich'sToys, Toadwart, 1 invisible), 296 guests, and 3 robots.
Topics128,087
Posts1,055,999
Members48,430
#1104171 05/22/2015 5:51 PM
Anyone found the correct lower door hinge check link spings? They are not the typical "C" shape. One per hinge.
I had someone refurbish the hinges on my '50 Chevy COE, using standard Advance Design hinge springs, available from our vendors. There are two per hinge, above and below the hinge strap.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I will post pictures of my springs off my 48 gmc ffr 350 when I get home. The hinge will not fit in the pillar hole with those C type springs. My hinges have only one spring per hinge.
