1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 5 New Guy | | New Guy Joined: May 2015 Posts: 5 | Anyone found the correct lower door hinge check link spings? They are not the typical "C" shape. One per hinge. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I had someone refurbish the hinges on my '50 Chevy COE, using standard Advance Design hinge springs, available from our vendors. There are two per hinge, above and below the hinge strap. Kent | | | | | Joined: May 2015 Posts: 5 New Guy | | New Guy Joined: May 2015 Posts: 5 | I will post pictures of my springs off my 48 gmc ffr 350 when I get home. The hinge will not fit in the pillar hole with those C type springs. My hinges have only one spring per hinge. | | |
