7 members (kades51, Forty9, Peggy M, greenie-reddy, ShopRag, Bill Hanlon, 1 invisible), 88 guests, and 3 robots.
Topics128,185
Posts1,057,281
Members48,467
#11039 04/03/2005 5:48 PM
Junior Member
Junior Member
Will a 292 or 261 bolt right up to the bell housing behind a 216?
#11040 04/03/2005 10:14 PM
i know the 292 wont. it takes the newer bellhousing which also fits small block v8's. i do believe youll be alright with the 261, they use the same as the 216.
#11041 04/04/2005 5:20 PM
I put a 292 into a 54 6400 and it bolted right up! I took out the 235 that the PO had put in. I don't understand why I was able to do it if it doesn't work. Redcoat
