| | | Forums66 Topics128,183 Posts1,057,262 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11039 04/03/2005 5:48 PM | Joined: Jan 2005 Posts: 26 Junior Member | | Junior Member Joined: Jan 2005 Posts: 26 | Will a 292 or 261 bolt right up to the bell housing behind a 216? | | |
#11040 04/03/2005 10:14 PM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | i know the 292 wont. it takes the newer bellhousing which also fits small block v8's. i do believe youll be alright with the 261, they use the same as the 216. | | |
#11041 04/04/2005 5:20 PM | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | I put a 292 into a 54 6400 and it bolted right up! I took out the 235 that the PO had put in. I don't understand why I was able to do it if it doesn't work. Redcoat | | |
