5 members (52Carl, Bill Hanlon, Danielbolt, 2 invisible), 47 guests, and 4 robots.
Topics128,180
Posts1,057,163
Members48,464
#11039 04/03/2005 5:48 PM
Junior Member
Junior Member
Will a 292 or 261 bolt right up to the bell housing behind a 216?
#11040 04/03/2005 10:14 PM
i know the 292 wont. it takes the newer bellhousing which also fits small block v8's. i do believe youll be alright with the 261, they use the same as the 216.
#11041 04/04/2005 5:20 PM
I put a 292 into a 54 6400 and it bolted right up! I took out the 235 that the PO had put in. I don't understand why I was able to do it if it doesn't work. Redcoat
