2 members (FAST55, 1 invisible),
69
Mod | | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 4 New Guy | | New Guy Joined: May 2015 Posts: 4 | Hey guys, just bought a 48 (titled 48 ) semi. I am guessing it is an ARC723 but not 100%. Please take a look at the pictures and tell me what you think. The data tag reads GVW 22000 CGVW 36000, One more question do you believe a CDL would be required to drive the truck?
Thanks Paul [IMG]https://www.flickr.com/gp/133169670@N03/yf8inw[/IMG] | | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | That's not a '48. Looks like a '39 or '40 model. If you can find the VIN number, post that. That will tell us for sure | | | | | Joined: Jun 2013 Posts: 50 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 50 | Yes, definitely not a 48. I agree on the 39/40 GMC, cool truck. Here is the link to the pic. link
| | | | | Joined: May 2015 Posts: 4 New Guy | | New Guy Joined: May 2015 Posts: 4 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, the link doesn't work for me, wants me to sign in??? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | It worked for me.
I think it is probably around an 800 series and they built them through about 1949 or so. I can't find my book on the 40's larger trucks, but it definitely could be a 1948. Its missing the headlight buckets. They were attached down at the bumper.
As for the CDL, it depends on your state. Texas has no provision for CDL exemption for antique trucks. Only farm trucks. If you cross state lines with it, you lose your home state exemptions.
It is a serious matter, because if you are in an accident, and it is found that you should have a CDL, it is the same as no license. CDL requirements are getting more stringent all the time. 2 serious violations in 2 years and your license is revoked. And you must have a current medical card signed by a doctor who is in the national registry. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The medical is only necessary if you are driving commercially. I've had a class A for decades and haven't driven commercially for years so have no current medical, but I can use a semi to haul a farm tractor to my shop or take an antique to a show in another state. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, my vote is for 48, I can see the headlight stands coming up from the frame which is how they started mounting them after the war, prewar headlights mounted on the sides of the grill housing, but I don't see any mounting holes there. | | | | | Joined: May 2015 Posts: 4 New Guy | | New Guy Joined: May 2015 Posts: 4 | Correct it does have the headlight mounts coming up from the frame. As a bonus I do have the headlights! | | | | | Joined: Feb 2012 Posts: 36 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 36 | A CDL is required to drive trucks over 26,001 pounds. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | As mentioned above by 3B, & Crenwelge, that truck style was used in the Heavy Duty Lineup until 1949. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Oh yeah, If it's a 22000lb. gvw, it's going to be either a ACR622 (136"in. WB), or ACR623(160"in. WB), depending on the wheelbase. The 700 series trucks had gvws from 27500-30000lbs. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 26,000 is the number.
Is it a 426 gasser or a 4-71?
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | My Literature tells me, that a 600 series these years would have a 361ci. gas engine. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | That is the same engine series, 361, 426, 503, gassers.
| | | | | Joined: May 2015 Posts: 4 New Guy | | New Guy Joined: May 2015 Posts: 4 | Finally had a chance to look at the data tag and it is an ARC622. Thanks to everyone that has responded. Now to get the brakes bled... | | |
