2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | ISO the 1/2 inch oil lines to and from the block on my 261. I did a search and checked Flaps,Patco, Napa and Cat. Thanks for the help.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | They probably will need to be custom made. Try Nashville Rubber and Gasket, one block off Elm Hill Pike near Briley Parkway. If they can't help, there is a gasket and hose place in the old Sears auto service center at 6th. Ave. and Lafayette St. in the same area as the Nashville rescue Mission that's housed in the old Sears store. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to use 3" to 4" long pieces 1/2" NPT solid pipe coming straight out of the block (steel or brass or stainless steel). Or, use bendable 1/2" tube with fittings (as shown at the link below). GM used bent metal tubes, presumably to clear exhaust system parts. http://chevy.oldcarmanualproject.com/shop/1959trucksup/59ctsms0803.html | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thanks Jerry and TC. Nashville Hose was able to supply one hose and reuse my fittings on the second hose so we are moving forward.Mtneermike
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | got them installed. Not orginal however the best I could do.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
