4 members (RoadsScholar, Peggy M, Otto Skorzeny, 1 invisible), 137 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
#1102767 05/15/2015 2:01 AM
ISO the 1/2 inch oil lines to and from the block on my 261. I did a search and checked Flaps,Patco, Napa and Cat. Thanks for the help.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
They probably will need to be custom made. Try Nashville Rubber and Gasket, one block off Elm Hill Pike near Briley Parkway. If they can't help, there is a gasket and hose place in the old Sears auto service center at 6th. Ave. and Lafayette St. in the same area as the Nashville rescue Mission that's housed in the old Sears store.
You might want to use 3" to 4" long pieces 1/2" NPT solid pipe coming straight out of the block (steel or brass or stainless steel). Or, use bendable 1/2" tube with fittings (as shown at the link below). GM used bent metal tubes, presumably to clear exhaust system parts.
http://chevy.oldcarmanualproject.com/shop/1959trucksup/59ctsms0803.html
MtneerMike #1102940 05/15/2015 11:48 PM
Thanks Jerry and TC. Nashville Hose was able to supply one hose and reuse my fittings on the second hose so we are moving forward.Mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
MtneerMike #1103161 05/16/2015 11:49 PM
got them installed. Not orginal however the best I could do.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
MtneerMike #1103164 05/16/2015 11:57 PM
Looks good.
