2 members (Gdads51, 3B), 116 guests, and 3 robots.
Topics128,195
Posts1,057,379
Members48,469
#110261 10/04/2004 3:23 PM
mj
Offline
I just finished removing the engine and tranny from my 51 Chevy 3100. Now I want to remove cab.
Any pointers on the best way to remove the steering column , everything else is already out. One guy told me it is nearly impossible to get the cab lined up again when it's put back on . I don't see it that way , any comments?
#110262 10/04/2004 3:53 PM
Don't attempt to separate the steering column from the steering gear box. Disconnect the pitman arm and remove the bolts holding the box to the frame. As I recall, there are one or two bolts kind of hidden on the inside of the frame. Whole unit then slides out.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#110263 10/04/2004 3:57 PM
mj
Offline
Thanks Jeff!!!! I am almost down to the rolling chassy. This will help .
#110264 10/05/2004 12:09 AM
Junior Member
Junior Member
MJ I took my cab off (59) when I went to put it back on I looked over my original assembly manual, it noted all the measurements and dimensions. I then proceeded to ignore all info and reunited cab and chassis. Worry faded when I had no problems realigning the front sheetmetal. Somehow I don't think measurements were all that critical as they make out in the manual.
Just my $.02
rebuild not replace
#110265 10/05/2004 1:27 AM
Easy to put cab in place. You can move the
cab around by hand when you need to line up
holes for reattachment. Very easy.
#110266 10/06/2004 3:38 AM
I used a racheting web tie down ztrap through the windows and an engine hoist (cherry picker)to pick the cab from the frame. Took it off and reinstalled it by myself.
Just go slow and helping hands always make it easier.
