7 members (52Carl, Robert Crandall, 1955 1 Series, Tinker5, Leo, Mike B, 1 invisible),
146
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,863 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 34 | Will a 2 headlight fender from a 58 fit on a 56 3200?
thanks. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It will, you may need to retrofit a bit... It may look funny coming down the road. Got 2 fenders?
| | | | | Joined: May 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 34 | I like the look of the 58-59 headlights but the truck I'm looking at is a 56. Don't have a stove bolt yet but I hope to soon. I'm a chevelle guy | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | The technical name for the piece that runs between the front fenders that the grill bolts onto and ties the front sheet metal pieces together eludes me.... But I'd look for one while looking for fenders as the 'fit' at the top where they met could well be different, IDNK from experience just a heads up of likely area of concern.
If there was an issue you could easily make your own patch panels and weld them into the 56 if need be.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 34 | Thanks for the heads-up CASO. The truck I'm looking at, that piece you're talking about is in rough shape so it we decided to try the later-style front fenders I wouldn't be worried about having to modify or fabricate that piece. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Your welcome but... that doesn't mean Bart isn't right
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I have a 59. Quick answer is yes they will fit. but.... you will need 2 fenders inner pannels , a hood , the cross piece behind the grill and a grill . headlite buckets and bezel and maybe a radiator support. I would look for a 58-59 they are around and they look much better than the one headlite ones. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Whoa! there partner. The Tri Five Trucks and Cars are THE best looking. Single Frenched headlights.  I like the dual also but a bit google eyed on TF trucks.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | I don't know, Bartamos...I'm with 59chevy36 when referring to the 58/59 he says, "they look much better than the one headlight ones." Guess that's why they make vanilla AND chocolate; everybody has different tastes. (55-7 look pretty good, too).
Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: May 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 34 | Thanks for the input guys. Pulled the trigger on the 56 I was looking at. The single headlight look is growing on me. But If I ever get another it will be 58-59. The dual headlight does look better imo but the wife likes this 56. I get a new project AND the wife is on board? Win-win haha | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Whoa! there partner. The Tri Five Trucks and Cars are THE best looking. Single Frenched headlights.  I like the dual also but a bit google eyed on TF trucks. I'm going to have to side with bartamos, since I have two of them.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
