| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Yesterday I adjusted the steering box. 48 3100. It had slop of about 5 minutes on a clock. I followed the book and got the required results. When I finished I noticed there was more tension in the middle than near the ends. Is that normal? The box also had dark colored fluid that stunk like rear gear oil which leaked towards the wheel well. I am thinking of adding penrite steering box fluid from restoration stuff, escodido CA.
Any advice or thoughts? Thanks
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is normal for the gear to be tighter in the center. If it binds going across center you need to back up the sector adj. a little. If it leaks fluid you need to use a thicker grease. A lot of guys use John Deer Cornhead grease. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The Penrite is a very good choice, expensive but still a good choice, that'ts what I've been using since I rebuilt my gear box. Most of the guys are using John Deere Corn Head grease, which is close to the flow characteristics of the Penrite. Its a couple bucks a tube vs. fifteen to twenty w/shipping for the Penrite.
The leakage you're seeing is quite common. Cause is a worn seal or shaft, usually both. New seal and Speedi Sleeve will stop that.
Yes, there will be a little more drag in the center of the movement, check the manual, I believe it addresses that. If not, there is a film strip that I think Brad has posted here and it might be on TOCMP, also it comes with a rebuild kit and you can order the booklet separately.
dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you for your replies and comments. I'm moving in the right direction.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | With my new 3.55 gears and tightened steering box I felt very comfortable driving 60 mph on the highway here in Los Angeles.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Perfect timing! I picked up a spare steering box I plan to crack open today for a rebuild. That slide show is going to be of great value to me. Thanks Brad. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Set the sector preload so the turning torque at the steering wheel nut increases 10 in/lbs. as the gear passes over center. With the drag link disconnected and an inch-lb. torque wrench on the wheel nut, turn the steering gear through center and record the numbers. For instance, if it takes 10 in/lbs to turn the shaft when approaching the center point, it should rise to 20 in/lbs as it goes over center and drop back to 10 after the high point is passed. If torque rises, drops at center, and rises again, the worm gear is worn out and must be replaced. Jerry
