Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (JW51, baldeagle, Oswald, Gdads51, Jay R, greenie-reddy, 1 invisible), 43 guests, and 4 robots.
Topics128,004
Posts1,055,247
Members48,418
#1101669 05/09/2015 4:25 AM
My 1956 speedometer reads 25mph when I'm going much faster than that, is this a take it apart and clean it issue or it's broke find a new unit issue?
Also got a loud squeel from under the dash the last time I had it out. The squeel didn't last long enough to ID where the sound came from...maybe the speedometer???
I don't have any history with the gauge cluster, we found it at a swap meet, took it apart and set the OD back to zero (looked clean inside) and we thought it was ok to install in our project truck...guess it wasn't, lol.
Thoughts???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mine made that squeal when I disturbed the cable during my rewiring. I attached it to my wiring to clean up the fire wall. It must have been tight or on a bad angle. I let it hang free and the squeal got better but was still there. I removed it, sprayed it down with brake cleaner, put bearing grease in it and made sure it was loose when it went back in.
IMHO it might be a good idea to remove your cluster and clean\oil it. Stopping at 25 doesn't sound healthy.
Moderated by  ndkid275, Phak1
