3 members (kades51, 66flea, 1 invisible),
113
Mod | | | Forums66 Topics128,134 Posts1,056,736 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Hello All,
Has anyone found or made different colored lenses for their cluster indicators and high beams? I realize I can pull out the lens and just run the color light I want. I would rather my application look and feel as if GM did it back in the day.
Bingo chips are the same size 22mm-7/8" but there is not enough "meat" there to melt it to fit around the tube.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Not sure what you want to do? Change colors? fix faded colors? Replace original with original style? Don't know what "cluster indicator" means? There is High beam indicator, turn Sig indicator and gauge lighting. Assuming you want to fix original, they are available, the cardboard light tube and the green lens. You can use photographers "Gel" also. Any camera shop.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Thanks Bartamos,
Do you know if photographer's gel is made of? Do you think it will easily melt on a form?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Not sure what you want to do? Change colors? fix faded colors? Replace original with original style? Don't know what "cluster indicator" means? If I can get it in my head what you are doing/what you what to accomplish, I may be able to help. I have had plenty of TF trucks. Please help by explaining the quoted remarks. I'm not as sharp as I once was but as sharp once as I ever was.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Hey Bartamos, I appreciate your help, I want to replace these things with blue or amber ones: http://www.classicparts.com/1955-59...Lens-pr/productinfo/24-612/#.VULnapVFCM8Since they don't make them in blue or amber, I am looking for something similar that will look stock. If I cant buy something off the shelf I don't mind making it. I am modifying a blue lego lighsaber for the high beams since it is a perfect fit and they don't make replacements. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Just some quick thoughts is all I have:
1.You can cut the GEL into a diameter that will fit down inside the tube. It is a material like mylar sort of. A thin sheet stock of colored "plastic". 2. If you find something that fits you can paint it with amber light bulb paint. 3.You can drill out the middle of one of those green caps in your link, leave a lip, and glue gel or equivalent down inside on the lip. That way it fits the tube.
I will report back with the results.
| | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | I noticed a nicely colored plastic water bottle while out doing errands. Since I already have the bottle I gave it a try. I cut the bottle, chucked an old chisel. I took a socket large enough to fit around the chisel top. I heated the chisel with a torch. After about 10 seconds of heating I put the plastic on top of the flat side of the chisel. Pushed down on the plastic with the socket to form around the head of the chisel. [IMG]http://i103.photobucket.com/albums/m127/59apache/Materials_zps9yxfwxek.jpg[/IMG]Though the prototype is not perfect it is a step in the right direction. I need to improve my buck system to make perfect ones. [IMG]http://i103.photobucket.com/albums/m127/59apache/Signal_zpskj0rnkkf.jpg[/IMG]Note that there was no contact with the plastic and the torch. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Very ingenious... and repurposing also!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Thanks Bartamos  | | |
