3 members (2-Ton, 1955 1 Series, Phak1), 126 guests, and 2 robots.
Topics128,091
Posts1,056,449
Members48,443
#1101433 05/08/2015 12:10 AM
Found a box under seat had a pushrod in it. Doesn't look bent the motor does run and idle little rough so I took off the valve cover to see why the pushrod is under seat. Yup found the rocker arm broken off pushrod side #1 cylinder intake valve. Haven't checked the valve yet.
My question is will a rocker arm from a 1951 216 be the same?
Or what other rocker arms fit the 1952 235?
1947.5 Chevy 4100 red primer
1951 Chevy 4400 grey primer
50-53 the 216 and 235 rocker arms look to be different;
http://chevy.oldcarmanualproject.com/parts/1929_54/104.HTM
235's blocks are 1/8" taller, so the pushrods are different.
My Blog
Thank you guys I guess I'll be on the hunt for one of those
I just reread your post and I see it is a rocker you are looking for.
1950-58 235 rockers interchange. 1959-62 can be used with a slight modification.
My Blog
Thank you pre 68'dave
