9 members (Slick Willy, Lostbuthaulinass, Uncles51, Hotrod Lincoln, homer52, fonz8261, greenie-reddy, Otto Skorzeny, 1 invisible),
144
Mod | | | Forums66 Topics128,134 Posts1,056,410 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | Found a box under seat had a pushrod in it. Doesn't look bent the motor does run and idle little rough so I took off the valve cover to see why the pushrod is under seat. Yup found the rocker arm broken off pushrod side #1 cylinder intake valve. Haven't checked the valve yet.
My question is will a rocker arm from a 1951 216 be the same? Or what other rocker arms fit the 1952 235?
1947.5 Chevy 4100 red primer 1951 Chevy 4400 grey primer
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 235's blocks are 1/8" taller, so the pushrods are different.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | Thank you guys I guess I'll be on the hunt for one of those
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I just reread your post and I see it is a rocker you are looking for. 1950-58 235 rockers interchange. 1959-62 can be used with a slight modification.
